NOx sensor & oil leak E250 2014 (77K MI)
Also, the last time I had the belly pans off the car I noticed oil seeping at drivers side of car, just a drop or so. I mentioned this to the dealer and dealer replaced two seal rings and two gaskets plus one metal seal. The description calls the parts upper and lower O-rings between mixing chamber and throttle valve. Part (# 651-091-04-60) (651 091-02-60) (651-142-04-80)
( 651-142-24-80).
All of the above work was no cost to me, my extended warranty covered the repairs. Possibly emissions warranty covered NOx sensors but invoice does not say.
Hope this helps someone in the future.
But otherwise good luck with your vehicle.
