GTs- 086700 _ the system pressure of the transmission is implausible
then i make diagnostic, the scanner shown this DTC '086700 _ the system pressure of the transmission is implausible'.
i did some work in gearbox two weeks ago : i change oil seal, the gearbox lost some oil not too much, i check the oil level it was good; but I'm not sure that this DTC caused by oil missing.
i'll be tanksful for any help
Normal procedure would be clearing it and hoping it will not return.
