ELI5 - OM642. Good? Bad?
Old Dec 31, 2021 | 04:30 PM
W203fanatic's Avatar
2012 ML350 Gas
I've been reading countless amounts of threads and still hard to get a decent conclusion about this engine. Some people love it, say its bulletproof. Others say its the worse engine ever made.
I found a 2012 ML350 with only 25K miles and wondering if I should pull the trigger or not.
From what I can understand the issues with the Adheater/EGR can be avoided if I just use the correct oil and do oil changes at 5K miles instead of 10K miles. And change the oil filter every 2.5K miles? Also buy only Diesel from Shell V-Power stations?
Worst case, If I do get these Adheater/EGR issues, I can just do the ECU firmware hack and just delete those components and not get any issues.
Can someone sum it up to me? Or should I just get a gasser however seems 80% of the ones for sale are all BlueTecs
Old Dec 31, 2021 | 07:27 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
What's your location?
In USA this site will give information about status of Mercedes-Benz Bluetec Update
https://bluetecupdate.mbusa.com/home
If it applies, it will follow with 4 years warranty on most of engine parts.
Hard to beat the deal.
OM642 is 20 years on the road and still produced. When it had weak points like oil cooler seals, or intake flaps, it is lovely performer.
Old Jan 2, 2022 | 02:44 AM
hyibin's Avatar
E270 cdi W211, E350 cdi W212, ML350 BlueTec W166
AdBlue has nothing to do with oil change. 642 is a solid engine. What you need to look at is service history.
Old Jan 2, 2022 | 09:35 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
But, the wrong oil can damage the related sensors and catalyst, which, I think was the OP's point.
Old Jan 2, 2022 | 09:43 PM
hyibin's Avatar
Wrong oil will only clog the DPF due to high ash.
Old Jan 3, 2022 | 10:12 AM
John CC's Avatar
That's not what I've heard. I guess we'll have to agree to disagree.
Old Jan 3, 2022 | 04:53 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
See the link below, lots of info. Glean from it what you will..
PS: This ought to light a fire under some... LOL
http://www.stephensservice.com/bluet...ssuesproblems/
