Does the OM642 use a copper washer on the oil drain plug?
Last time I check, it does have copper washer, but it is reusable. When you notice lot of scratches- just sand it.
Personally I would never reuse a crush washer if you actually have to remove the drain bolt - they are single-use items by definition and at less than $1 simply not worth the risk - but if you suck the oil out through the dipstick tube you'll never have to worry about it plus it is a lot easier.
The tubing was soft, so with some pressure it would seal the connection.
Not most comfortable to hold the tubing with 1 hand and pump with other, but doable.
Than, since 1 of the friends borrow my hand extractor, I bought 12V pump for the job. Slow , but I do other things around when it is pumping.
Dont see how the above link relates to the question?
engine on mine is OM642
Oil drain on other hand was placed horizontally 1/2 way on the side, what had to leave several tablespoons of oil
This is still hair-splitting comparing to 1/2 to full cup of oil trapped in upper engine parts.
Some engines, like Powerstrokes make oil changes leaving 2 liters of oil in fuel pump and they don't make special intervals for it.
I use this extractor:
https://www.ebay.com/itm/22502642007...gaAjyWEALw_wcB
It uses a plastic tube that inserts into the dipstick tube for extraction, rather than forming a seal with the dipstick tube itself, as some extractors do. I like the price (less than half of what most similar capacity plastic extractors cost) and the rugged all-steel construction, which is FAR superior to the cylindrical plastic extractors, particularly when creating high vacuum values for viscous liquids. Also, with the 'tube inside a tube' method, you can use it to extract fluids on many other vehicles/RVs/ATVs/boats/power equipment etc. etc., most of which are NOT designed like Mercedes for oil extraction via sealing at the dipstick tube.
So, it's cheap, far stronger than plastic extractors, like Mityvacs, and versatile. Give it a try if you're wanting an easy, low-cost entrance into using fluid extraction as a maintenance method.
