2014 e250 Bluetec ScanGauge 3 DPF Regen
1. Does this seem like the correct behavior?
After reading some of the posts on this forum I assumed the regeneration process would stay on (active) for few minutes and not just for few seconds during the acceleration.
2. What triggers the DPF regeneration and which gauges should I be monitoring?
There is a Regen Trigger gauge which currently is at about 60%
3. Does the Regen activate once the Regen Trigger reaches 100%?
My current DPF fill is at 42%, the gauge also indicates there has been 19 regens and the average distance between regens was 720 miles. Any additional info about this topic would be greatly appreciated since the MB diesel world is all new to me...
A regen usually will come on when it is required, the vehicle is warmed up to temp, and steady state driving. Not sure about these cars but my truck will even do it at idle (if warmed up) if I leave it running during a regen.
More then likely the trigger percentage will actuate it at some given percentage. The 750 miles will depend on driving style and conditions.
There are several parameters, who will trigger regeneration and several parameters that will prevent it.
So most common regeneration is due to soot build up. Once your gauge will show 100%, it might take additional minute to start the regeneration.
When you have good DPF, who doesn't build soot easily, there are mileage and fuel consumption limits.
Better scanner will pull you history with explanation what and when happened.
SG III seems to be really good gauge, but I used SGII for years, where regeneration X-gauge was pretty lousy. I used DPF temperature to monitor pending regeneration.
Alse consider that DPF do self-regeneration, what might be the light you see when accelerating.
Lately I was pulling 4000 lb trailer with my Sprinter and climbing 15 miles Baker, CA grade I was really pushing it. My soot contest dropped by 30% on this climb as DPF temperature went above 500F. Normal regeneration temp is about 580
I concluded that it is "Italian tuneups" I do as I don't hesitate to "floor it" entering freeways, so don't hesitate to do it.
pic of the gage
