2007 e320 Intermittent boost. Help with codes.
Old Oct 3, 2023 | 08:45 PM
rpallesen's Avatar
2007 E320 W211 Bluetec
my 2007 OM642 has internment boost problems. Sometimes it will work. And when it works it stays working for a few days.
I have done turbo actuator control tests and it moves properly. "I also replaced it"
Star is showing
Charge pressure positioner. >= 85.0. reading 5.0
On/Off ratio of component Y94 (Quantity control valve) (24.0..31.0) is always high. 42%
The system is throwing codes:
Rail pressure monitoring via volume control valve Rail Pressure deviation due to air forming in the system.
Hoping someone can give me some guidance. I previously had an injector problem that was caused by water which I resolved.
