RESEAL OIL COOLER (OIL COOLER LEAKING)
@Diabolis, I've got a 2014 ML350 Bluetec (you've helped me out before
), is there a way to tell if my ML was made with those 3rd gen Oil Cooler seals? If so, should they last the life of the car?
), is there a way to tell if my ML was made with those 3rd gen Oil Cooler seals? If so, should they last the life of the car?@Diabolis I would like to know about the seals as well. I have found many kits online that do not specify what gen they are. I am thinking about diving in myself next spring. Will give me time to research and have proper parts and tools. (I do have experience on other brand cars with engine rebuilds before sombody says anything)
I got the service manual on eBay, just ordered today. I don't think I'm supposed to post seller links, so look for "Mercedes Smart - WIS / ASRA & EPC EWA Workshop Service Repair Manual Set on USB". I bought from a US seller for ~$33, but they have overseas sellers who are selling the discs for like $6 if you're willing to wait. I haven't gotten it yet, so no idea how good/ bad it is.
Cheers,
Tony
On a side note, after changing the oil, the engine is running considerably better. Better starting, acceleration from stop, and fuel economy as per the onboard computer. Am I crazy to think the old oil was messing up seals?
Front of alternator and lower radiator hose fitting.
Top of alternator, side.
You obviously have an issue which needs to be addressed, so if you can't figure out where the leak is coming from (let alone fix it), you need to take it to a trained mechanic that can. Sorry.
As noted, though - find the highest spot - that will at least get you close. Then clean it good and re-observe.
This isn't one where you need a "specialist" mechanic - any decent mechanic can track down a leak.
Add some dye, if you want.
I need One of the portable scissor lifts, gonna use it out in the street where I park!! Do a full engine rebuild there...hahahahahaha!!! Neighbors will love that.
But really, I am thinking about driving to the next town over to find a mechanic. Will need to add hotel room to the cost of repairs! Ugh!
It is such a slow leak I literally dont see any fluid levels going down. I have not checked that one in a while though. Good idea.
