RESEAL OIL COOLER (OIL COOLER LEAKING)
Thanks!
Tony
Seals alone might cost about $10, but usually mechanics replace whole cooler for about $200.
The kick is that it takes >20 hr of labor to get to the cooler, so with dealer charging above $150/hr that can bring quite big bill.
What are your DIY skills?
The job is not very difficult, but taking big chunk of engine apart require some experience.
Is there a way to get eyes on the cooler so I can see how bad it is? The dealer gave ****ty stock photos, that are not even the same car, as examples of the problems. I have not noticed a significant drop in oil level on the dipstick, I am wondering if it is even worth the effort.
cheers,
Tony
But if you see oil dripping via drain hole on driver side, or at the end of the valley, the cooler is the only source of possible leak there.
When you get to the job, make sure you clean the valley perfectly. Other member reported that when dealer did his seals, they let the dirt dropping into oil passage and engine seized couple miles from the shop.
I have general oil around the valley, but I don't see a drain hole. I thought it was coming from the oil filter housing. I will poke around when I change the fuel filter. Any pictures of the drain hole or location?
Mercedes replaces 27 different seals and gaskets when they do the job because you can't reuse the old gaskets / seals to put things back together properly without ending up with an air leak somewhere, so even if you reuse the oil cooler itself, you'll still need about ~$600 worth of parts. You don't necessarily need a hoist - most of the work is done from the top - but you'll definitely need a warm garage, an empty shelf ore two to keep all the parts that you'll end up taking off and putting back on, and probably three to four full days to get it done.
Here's a link to a more detailed post on the subject: https://mbworld.org/forums/m-class-w...ler-seals.html. There is another link in the original post there that leads to another site with 16 pages worth of additional info on the seal replacement job, so to save yourself a lot of grief make sure you go through everything before you decide to tackle it. It is not a job you can do in an afternoon on your driveway, so you might be considerably better off paying a professional to do it.
You can't see it unless you lift the car and poke with snake light, but oil on the side of the engine tells a lot.
One thing I asked him to do was to apply some sort of high-heat RTV (carefully) to the seals, hoping that would better seal for the long run. Time will tell!
Something I've been pondering, though... if/when I have to do this job again... I wonder how hard it would be to create a block-off plate in the valley of the engine and plug/barb whatever lines need that... and use a regular 'ol oil cooler mounted up in the grill somewhere (or possibly underneath). I'd have to figure out where to tap into the oil supply and where to return it - but I imagine that should all be doable.
I was also thinking of fabing a custom bumper to relocate all the coolers...but that is a different story.
Only problem with that idea is the block off plate still has a o ring of some sorts. Now its possible that you could figure out a better system however its the same problem. The AN fittings ofcourse once good should stay good but the adapter plate is the issue.
I mean, it's great that you're looking at options that would require less or no maintenance in the future, but the latest (4th gen) seals are not known to leak... so why bother going through the pain and expense of fixing something that isn't likely to break again? Just curious.
Cheers,
Tony
I haven't heard any definitive info about the latest (4th) gen o-rings being the be-all, end-all. But honestly, I haven't really dove into that research very much. What I do know is that if we're now on the 4th version of these... I'm skeptical that the o-ring composition is the issue. Meaning, it shouldn't take 4 revisions to get composition "correct". I suspect the issue is more about the mating surface of the block/cooler and/or possibly vibration/movement between the two items. Just thinking outloud there, though.
There have been four different revisions of the oil cooler seals. The first two were from rubber / silicone and didn't last long (they were orange). The third and fourth revisions are made from Viton (they're purple) and are better, although the third revision has also been known to leak when improperly torqued. The fourth and final revision was a redesign that has a larger seal area and has so far been leak-free. On the third gen seal you can see the exposed substrate material on the inside of the "O" whereas the 4th gen has thicker rings with no exposed substrate on the inside of the "O".
The third-gen seals were the last ones installed by the factory before the OM642 diesel ML production ceased at the Alabama plant where all of the NA vehicles were made. I think the fourth gen seal was released sometime late in 2015 so after NA vehicle production ended.
Just kidding, of course. You bring up a valid point. Maybe a semi-permanent adhesive-sealant could help?
Not voice of reason just pointing out something. Get the correct o-rings in there and save your money. Proper O-rings in a properly designed setup are generally the way to go unless its something like a metal to metal flat flange with very even mating surfaces and a ton of clamping force which ya arent going to find on the cooler. Think a head on a engine or two halves of a turbine.
Cheers!!
MudFoots
Cheers!!
MudFoots
I recently noticed that the leak goes away as the engine warms up. And that the oil was showing slightly over full on the dipstick. Almost time for an oil change and it is still full on the dipstick.
really wish I had my old shop, this is frustrating!
Thank you all for the input. One day I will get it fixed! 😁 😀
