Series of issues - turbo actuator and MAF issues
My Mercedes 2007 Gl320 (OM642) has had a series of issues and I'm wondering if they are related:
- Went into limp mode a few weeks ago with a P2015 (also had a P1408, P0472, P0234. I noticed the MAF had cracked and there was oil that probably damaged the swirl motor control so I did the resisitor bypass. I was not able to figure out how to see if the flaps were open but others said they usually default open so I went with it. I also replaced the MAF with an eBay special (maybe a mistake but it was $98 and I just crossed 250k miles).
- I cleared the codes and the P2015 went away
- After a bit of driving I got P2359 (charge pressure too high), P2631 (MAF sensor right sensitivity driftAir mass ratio for calculated quantity (top), and P2510 Check the component Y77/1 (boost pressure regulator) positioner signals fault.
- I read that I may need to reset the MAF so was hoping that was causing the P2631 so I used my Autel tool and did that
- The check engine light came back on after a bit of driving with same 3 codes P2359, P2631 and P2510
- I decided to try and swap the old MAF sensors into the new housing figuring maybe I got a bad unit off eBay. Car seemed to drive well for a bit then stuttered when I gave it a lot of gas and reactivated P2510.
Max
