Rattle noise under my shifter on my 85 300D
Old Jul 31, 2024 | 10:11 AM
hugho's Avatar
1982 240 D,1985 300D
I am a competent DIY mechanic with lots of MB experience with the 3 that I own. Recently I noted a rattling sound coming from the shifter area . The car has 260K miles and has the original tranny but otherwise runs fine. I change ATF every 40K miles and the pan is clean. What might cause this? trannys are just a mix of gears and clutches. what could rattle?
Old Jul 31, 2024 | 02:37 PM
nelbur's Avatar
1997 E300D
The plastic bushings on the shift linkage can break and fall out, at least on newer models. I am not sure of your model.
Old Jul 31, 2024 | 02:38 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Is the shift linkage tight? Failed bushings in Mercedes shift linkages are not unheard of...
Old Aug 1, 2024 | 09:49 AM
hugho's Avatar
Thank you Boys. I will crawl under her or get her on a lift ASAP.
Old Aug 17, 2024 | 05:25 PM
hugho's Avatar
shifter noise GONE
thanks again John and Nelbur. Indeed both of the shifter bushings were toast. Pressing in new bushings was exceedingly hard even with my homemade rig so I spent the big bucks and got the tool from Kurt in Bellingham which made it child's play. Fixed the issue. Yea!
Old Aug 17, 2024 | 09:01 PM
John CC's Avatar
It's not just the newer models. It's common in the W126, and the for car in my avatar the 1-2 gate is against the driver's knee and the 3-4 gate is against the passenger's knee. Pretty low on the list right now, though...
