Cls 400d EGR help
Old Nov 21, 2024 | 01:35 PM
Abbas ahmd cls's Avatar
Cls 400d EGR help
Guys I am very new to diesel mercedes the have 0m656 it's 2019 cls 400d.
i have egr error on it can someone point me in right direction please check the below error codes
Old Nov 22, 2024 | 12:12 PM
PeterNy5's Avatar
OM656 engine that means very modern but complicated EGR cooling system.
It is something like this: https://ergmoto.com/en/egr-valve-exh...km-p-5168.html
Error code you have (CURRENT), means the switchover valve is broken or wiring problem. If all wires to connector is fine, then it could be the valve itself. You can found that electrical piece as separately, you don't have to buy cooler body if it is okay (no leaks).
Old Nov 22, 2024 | 12:35 PM
Thank you for your reply. I will check and report back 1 quick question does this hurt engine performance. As car drives very normal the only thing which i notice is when it's cold or not very hot in the cabin car idles at 550 rpm and when it's hot it is at 700rpm at 550 rpm it vibrate alot however that is also because engine mounts need replacement however this idle rpm is very confusing 😕
