W164 Cold Weather Starting
Not a serious test, but mine started the other day at +5F on (I think) the 4th compression stroke. The only indication of how cold it was was the fact that my butt was freezing on the seat.
ps.. my daughter who moved to SK a couple weeks ago has since purchased a battery tender and a small booster that should help with the cranking anyway..
This ended up being a 3 relay problem. The glow plug relay under the hood, and two of the fancy time delay relays in the rear. The glow plug relay was switching on too late and the rear ones were staying on and draining the battery. The one under the hood was replaced with the new p/n mentioned above and the two rear time delays were being stuck on and replaced with same part number. Now it fires up without any heat application needed. Faster when it's not super cold over night too.
The two rear relays in the rear are the lower left ones, I believe M and K positions...maybe...I need a map of the relays to go with the fuse map.
