Help With Turbo Replacement
I was wondering where I could find a procedure for replacing the unit.
It looks like turbos going bad are a common problem and that replacement turbos run several hundred to several thousand dollars. I was wondering who makes a good quality unit that will not break the bank.
Thank You
Henry
Here it is:
https://bluetecupdate.mbusa.com/home
But what's the mileage and what symptoms do you have? Those turbos are recorded to last 300-400,000 miles.
I am new to Mercedes Diesels but not a novice mechanic. Sorry if my wording was confusing. I am a licensed Aircraft mechanic and have done a lot of work on Mercedes gas vehicles, and heavy diesels, I just haven't tried something like this yet.
Check this and tell me if any of the details documents is needed.
