Advise on the repair
Old Jul 15, 2025 | 11:54 AM
haist82's Avatar
cls63 amg
Hello !
Where is this line need to be connected people?
Old Jul 15, 2025 | 02:10 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
That is the bleeder valve for the filter. It looks like someone cut the valve off the filter and reattached it with that hose, probably to make it easier to use without making a mess. It doesn't connect to anything.
Old Jul 16, 2025 | 12:32 AM
haist82's Avatar
cls63 amg
thank you sir!
Old Jul 29, 2025 | 10:48 AM
haist82's Avatar
cls63 amg
I did some more research and found that it could be:Fuel Feed Line (to high-pressure pump)
  • Sends clean, filtered fuel to the high-pressure fuel pump (HPFP) or injection system.
    Can you shine some lite on this?
Old Jul 29, 2025 | 06:17 PM
John CC's Avatar
I think you will find my answer is correct. The two metal elbows are the inlet from the tank and outlet to the high pressure pump
Besides, the car wouldn't run if one of them wasn't hooked up. (or is that why you're asking?)
