New E550 Coupe
The price on the E-Class coupe in Canada vs the USA once you load them up and compare them comparable equipped depending if you are looking at 350 or 550 the price is about $1.9k on 350 and about $1k on 550 because the 550 comes standard with Napa leather and both come standard with metallic paint in Canada those 2 options are $1370 for Napa Leather and $720 metallic paint except for Diamond White which is $1,515. So if you look at a Diamond White with Napa Leather loaded comparable in an equipment to Canada Spec car which has tons more standard options the price difference after converting to US dollars comes out to $971 today. Now if you are comparing non metallic colors, sure the USA would be cheaper by that price on top of the above estimates I gave and in the USA the 2 most popular colors are non metallic black and white but that could also be partly because both are standard colors. I also noticed for example on 350 in Canada uses the same transmission as the 550 ie dynamic handling package which is not offered at all on the 350 in the USA which is worth something by itself as well.
I see, so you are missing the front 2 cup holders then completely? I wonder why they could not make the front cup holders like the ones in the back seat which are hidden by a wood roll-top cover. Either way I still think the European center console is much nicer looking, and would be perfect if under that door it had 2 cup holders. While I do like cup holders, I would never not buy a car over the fact it did or did not have cup holders that sounds silly if you ask me.
Thanks for the pics.
I had the dealer swap the OEM tails for the euro-spec tails before I took delivery as I wanted the amber turn signal lights.
https://mbworld.org/forums/wheels-ti...500-ml-gl.html
Paint: is this one of the new Mercedes "mat" finishes? or did you have to
"polish" (or un-polish) the factory paint (palladium?)
Wheels: I saw the detail king ads, I think those a "replicas" on the original
CLS AMG wheel, or are they original AMG (for the price he quoted I would be
surprised if they are AMG).
Lowering: How do you plan to do this? With the set up on the E550C I was
told it would be a new set of springs for the front and software upload for
the rear - only no one had the software available: not Eibach, not H&R...
only Brabus had something for the coupe.
Congratulations!
The coupe doesn't use AIRMATIC, the suspension is just coil springs. I have C63 springs I am going to have installed on Wednesday. Keeping the same shocks due to the dynamic handling component. I have no idea if the springs will work, but you only live once!
frustrating that no one has proper lowering solutions for the 550C....and no real
prospects in the near future either, due to low volume model, and apparently
even lower interest in any modifications in this segment.
I know the 550C is not AIRMATIC, but still, when I spoke to Eibach in Germany
they said that the rear will be a software lowering.
Please post pictures before and after lowering!
