c207 clear side marker
Old Aug 23, 2012 | 02:41 PM
  #51
houstone550c's Avatar
mercedes e550 coupe 2010
Can someone please help me?! I'm having trouble installing the side markers. I removed the three pins and got half of the side marker loose. I was able to unhook the part of the marker closest to the rear of the car. However, the part of the side marker near the front bumper is still held in place. But I am not able to tell what is keeping it in place. Any advice? Thanks!!
Old Aug 23, 2012 | 02:44 PM
  #52
Ultraman's Avatar
2019 E450 Coupe 4Matic; 2018 Audi Q5; 2019 Toyota Corolla Hatchback
Did you remove the bulb socket first prior removing the OEM side marker?
Turn the side marker socker counter-clockwise to remove from the side marker, after that, you can push forward the tab (slow and easy) from the side marker to detach from the front bumper piece.
Old Aug 24, 2012 | 12:54 AM
  #53
I'll try this over the weekend. i did not try to turn the socket first. thanks much ultraman. i'll let u know how it goes.
Old Aug 24, 2012 | 01:07 AM
  #54
Ultraman's Avatar
I believe 100% is the bulb socket blocking something inside the bumper so that the side marker cannot slide out.
Try it and report the status of your work.
Old Apr 3, 2013 | 03:35 AM
  #55
kingbaabu's Avatar
E coupe
can someone do a tutorial on how to install this? I've done it on my previous 335i and it didnt require me to take off the fender.
thanks
Old Apr 3, 2013 | 03:44 AM
  #56
kingbaabu's Avatar
E coupe
is it possible to just put like a dark black tint on the sidemarkers to save all the trouble?
