Sprint Booster
How to remove Throttle pedal to install Sprint Booster????
hi people does anyone know how to remove the throttle peddle so i can install my sprint booster adapter to the accelerator cable??
all your help is much appreciated.
many thanks
Al
many thanks
Al
W177 A250AMG 2019, W212 FL E250 with 63 kit, R8
check their website u need to cut the carpet a little as well and take out the harness and plug it in, it is a little more complicated then on BMWs.
V2 is good
V2 is good
Former Vendor of MBWorld
C-Class
2010 E 550 Coupe
C-Class
'12 CLS550; '11 GL350 Btc;
Does the Sprint Booster for the E350 sedan (w212) also fit and work equally well in the E350 Coupe (w207) without modifications to the booster or it's attachments? Anyone with actual Sprint Booster experience in the w207 with feedback? Seems to be well received by the w212 community here.
i have install the sprint booster on my E350 coupe CGI but when i am driving it will auto switch from green to red
if you set it to off it will auto switch to green than red ...this happens when the car is still moving .....can anyone advise on this
i have change 2pc of sprint booster and its still the same ...
thank you
thank you
Same engine and transmission as the E sedan. Should not be any difference. Have experience with it on a Infiniti G35 coupe and love it. Four years and no complaints.
C-Class
thank you
thank you
S.B.
2011 E350 Cab, 2010 B200
The SprintBooster sounds much like the 'SPORT' button on my 2011 E350 cab. When pressed to on and the car in 'SPORT" mode throttle response is significantly better. Am I wrong or does the sprintbooster do a different/better job?
Yes, there is a significant difference between Sport Mode and SprintBooster. Go to the W212 forum and read the SprintBooster thread. It's eleven pages and 254 posts and will answer all your questions. Lots of both pro and con arguments.
