Break in Procedure
Old Jan 24, 2012 | 07:15 PM
chrisdabeast7's Avatar
C300/E550 coupe
Break in Procedure
Last week i bought a e550 coupe and i was wondering if anyone else follows the break in procedures for their cars?
Old Jan 24, 2012 | 07:52 PM
vcruiser's Avatar
2013 G63 AMG
Everyone follows them if they respect cars!
Old Jan 24, 2012 | 08:01 PM
C300/E550 coupe
haha well do i have to drive extremely gently for 1000 miles because i seriously am inclined to press on the gas; does anyone know the proper procedure
Old Jan 24, 2012 | 08:11 PM
AlnoorK's Avatar
2012 E350 Coupe
+1
In the Mercedes's "In the Driver's Seat" book it says
-Drive your vehicle during the first 1,500km (1,000 miles) at varying but moderate vehicle and engine speeds
-During this period avoid heavy loads (full throttle driving) and excessive engine speeds (no more then 2/3 of maximum in each gear"
-Avoid accelerating by kickdown
-do not attempt to the slow the vehicle down by shifting to a lower gear using the gear selector lever
-select gear ranges 3, 2, or 1 only when driving at moderate speeds (for hill driving)
After 1,500 km (1000 miles) you may gradually increase vehicle and engine speeds to permissible maximum
Old Jan 25, 2012 | 10:41 AM
ronsc1985's Avatar
2012 E550 Coupe
Don't get carried away with what is in the manual. The same disclaimer has probably been in every manual forever. People who have built race engines and torn them down can tell you that it takes nowhere close to 1000 miles to break in engines and transmissions. If the rings haven't seated in the first 15 minutes of driving they probably never will.
The more important parameter is engine oil and water temperature before you hammer it. Just be aware that the oil temperature and therefore some internal parts take a longer time then the water to come up to operating temperature. The same applies to the transmission, differential etc.
If you are really serious you can bed in the brake pads but for a street car this is really not needed.
Engine and car break in is probably the fourth in old wives tales right behind sex, fishing and golf.
Old Jan 25, 2012 | 10:59 AM
cmcbenz's Avatar
CLE53AMG
i followed the procedure until 600 miles. sort of. i mean. if you just don't hammer it and take it above 5k rpm and just sort of ease the engine in you'll be fine. my engine is still awesome. but uh, i've had a lot of electrical problems and stuff, which sucks. hopefully you won't have any problems.
Old Jan 25, 2012 | 02:44 PM
mikey08's Avatar
11 E350 Cab, 18 GLS450
I have for all of my cars just kept it easy for the first 1K or so. No quick fast acceleration. I have a friend who builds race engines for bikes and cars and there is a reason why they replace the pistons, seals, heads and tranny for each race or run. Sort of the same on our cars, but not to that extreme. The initial wear of the cams, pistons and rings will determine the longevity of the engine itself. I have also on all cars changed oil early on the first change.
