E-Coupe - D1S bulbs removal
Can someone please tell me how to remove the D1S bulbs? Should I turn the bulb clockwise or counter clockwise in order to take it out?
As I know, the W204 model, they have 2 metal clips that secure the D1S bulbs. However, I found there are no metal clips inside the headlights.
Can someone please confirm or advise how to do this?
Thanks.
Thanks.
Beside, I am confident to take off the driver's side without going to the dealership.
No clips like the C class, I know what u mean cause i use to have one. After you removed the bulb, there is a plastic ring that you remove from the d1s bulb. U reuse that plastic ring with the new bulb you replacing which i assuming u upgrading to 6000k,8000k. That ring is what holds the bulb in the housing socket.
BTW, do you have any problem accessing the driver's side? I beleive the access door from the inner fender is pointing straight to the low beam plastic cap. Dio you need any special technique?
Is the headlamp housing secured / locked to the D1S bulb flange (not the plastic ring)? What is this plastic ring for? To increase the thickness of the D1S flange to enable to lock against the housing?
