Diamond Vision 5000k Bulb Swap
Old May 25, 2012 | 05:35 PM
lifterforlife's Avatar
2012 E350 Coupe
So I am swapping my stock bulbs out for some Diamond Vision 5000k bulbs and I had just a couple of questions. Im ordering them from powerbulbs.com and so far I know the low beams are H7 but i'm not sure what the bulb code is for high beam or the parking lamp (the inner lights next to the low beams). Anyone know what the codes are for high beams and parking lamps are? My goal is to change over all the yellow tint lights to white lights to match the slick LED DRL.
Old May 26, 2012 | 12:36 PM
emdem's Avatar
2013 E550 Coupe
RTFM - H7
Old May 29, 2012 | 12:19 PM
2012 E350 Coupe
I did read the manual hence I knew the low beams were H7, wasn't aware that the high beams and the parking lamps were H7 too.
Old May 29, 2012 | 07:59 PM
emdem's Avatar
2013 E550 Coupe
The manual lists all bulbs. pg. 123.
http://www.mbusa.com/vcm/MB/DigitalA...pe-and-Cab.pdf
Old May 30, 2012 | 01:03 PM
newyorktoLA's Avatar
2020 G63, 2021 E450 All-Terrain Wagon
You're going to install these bulbs and then reinstall the original yellow H7's because of horrible light output. If I were you, I would go straight to installing a nice HID kit; trust me, I've used these bulbs and I hated how little illumination these gave!
Old May 30, 2012 | 01:31 PM
emdem's Avatar
2013 E550 Coupe
+1
Old May 30, 2012 | 03:05 PM
2012 E350 Coupe
Thanks for the heads up... what HID kit do you recommend for our E Coupes?
