Bluetooth Audio Problems
2010 E550 Coupe
Anyone having problems w/ audio system locking up after using bluetooth audio connection on a 2010 E550 coupe (35k miles)? I have a iPhone 4GS running current version of IOS and all available updates.
System works terrific 90% of time but randomly freezes up when I restart car after shutting down engine for brief periods, e.g., gas fill-up in middle of long (3hr) road-trips. System appears to be functioning but no audible audio. Also SAT radio function will show message "Device not Found.' Problem is not solved if I simply restart engine or restart phone. Problem resolves itself after engine is shutdown for 1 to 2 hours.
Dealer has recently replaced audio controller & amp a couple of months ago under warranty but problem still surfaces.
Welcome to the forum.
You may wish to read through this thread over in the W212 forum:
https://mbworld.org/forums/e-class-w...mand-unit.html
Not sure if the problem is exactly the same as yours, but seems 2010's have had some Comand System issues that sound similar to what your experiencing.
Hope this helps.
Hope this helps.
