Upgrading the hockey sticks to the straight line LEDs...
Old Oct 21, 2012 | 08:32 PM
njzprettyboy's Avatar
R8 V10
Hello everyone. Recently picked up a 2010 E350C for my wife. Car is spectacular. I used to have a CLK500 which I loved, so driving this car brings back some memories. I was wondering if anyone has swapped out the hockey stick LED DRLs to the new straight line DRLs. Seems like I would need the LED fixture as well as the black plastic shroud that sits in the bumper. Does anyone have the part numbers for these pieces? Also, are there any other parts needed? Is the newer LED a direct plug in? Has anyone attempted this swap? Just for reference, I have linked my current DRL (first photo) and the one Id like to replace it with (second photo). It seems as though both bumpers are identical. Thanks in advance!
Old Oct 21, 2012 | 08:59 PM
ahmadk's Avatar
2011 E550 Sedan
I'm not an expert but if the 2 models share the same front bumper I don't see why you can't swap them. As for part # you can try www.parts.com
Old Oct 23, 2012 | 11:03 AM
gavrocool's Avatar
e350 coupe
You can change them very easy,go to your MB dealer.
Old Nov 3, 2012 | 04:58 AM
MrH's Avatar
MrH
2010 E550 Coupe
Also have the 2010 550 with hockey sticks. Has anybody successfully upgraded to stock straight led's? Part #? Checked with local dealer and was told it could not be done to different wiring on 2012/13 models.
Old Nov 3, 2012 | 08:23 AM
gavrocool's Avatar
e350 coupe
Go to a better dealer and check DR. NAB,s car to see the upgrade.
Old Nov 18, 2012 | 11:40 PM
nk789's Avatar
2003 c32
Hockey Stick to Straight LEDs
I also have a MY10 E550 w/AMG pack and interested to do this upgrade.
Old Nov 19, 2012 | 07:07 AM
Dr-Nab's Avatar
B8.5 Audi S5 3.0 TFSI Coupe
for models with AMG bumpers:
280 DRL
A 207 885 04 74 Left
A 207 885 05 74 Right
290 Ornamental Molding (chrome surround):
A 207 885 07 53 Left
A 207 885 08 53 Right
Option codes required
240 LED Daytime Running Lights
772 AMG Styling Package Front Spoiler
Old Jul 25, 2013 | 05:33 PM
69armando's Avatar
2011 mercedes e350
I did the upgrade and it looks a lot better. 2011 E350 hockey sticks to Straight.
Old Jul 25, 2013 | 08:57 PM
Cy3's Avatar
Cy3
2011 C350
For what its worth...I love the hockey sticks. Probably a case of the grass always appearing greener on the other side. While the hockey sticks might not appeal to you, the point I guess is that it DEFINITELY does not take away from the car in any regard.
Old Jul 25, 2013 | 10:15 PM
Camber53's Avatar
w207
after upgrading the led can the led dim at night ??
Old Jul 25, 2013 | 11:55 PM
hillcreative's Avatar
2011 E350 Cabriolet
If upgrading from the two round fog & DRL lights you will need to refresh the front SAM and code 240 to get that feature.
Old Jul 26, 2013 | 02:37 AM
Camber53's Avatar
w207
but i upgrade from hockey stick LED DRLs to the new straight line DRLs but it wont dim ..
please advise and its the same code
Old Jul 26, 2013 | 05:36 AM
2011 E350 Cabriolet
To be clear you had the "hockey stick" LED that would dim when the headlights were on and now you have the straight LEDs which will not dim and you used code 240?
Are the part numbers
204-906-89-00
204-906-90-00
Not sure what's going on here and will have to defer to someone that has done the identical conversion. I am currently converting from the round DRL/Fog combination to the above part numbers.
BTW it may help if you post what car/model you have
Old Jan 5, 2020 | 07:10 AM
Jigson's Avatar
Mercedes W212 E 350 CDI
I've also upgraded from hockey sticks drl's to straight led drl's.
And after that they won't dim at night.
Have used the search function but can't find anything with a solution.
Anyone that know how to ?
Old Jan 5, 2020 | 08:08 AM
hyperion667's Avatar
2012 CLS63
