DIY: Mercedes e550 coupe cabin filter
Old Dec 27, 2012 | 06:19 PM
lee16's Avatar
2010 E550
DIY: Mercedes e550 coupe cabin filter with lots of PICTURES!!!!
The following are directions for replacing the cabin filter on a 2010 Mercedes e550 coupe. I'm sure its the same on the sedan and e350 models. I am not responsible if you screw up.
Tools needed:
1. Small flat head screw driver
2. Torx set (T20)
3. New Mercedes Cabin filter (part # A212 830 03 18)
Difficulty level: Easy
Step 1:
Locate passenger side floor area
Step 2:
Look under the dash and you will need to remove three (3) torx bolts in these areas.
Step 3:
Pull down the floor mat and then pull down the carpet underneath.
Step 4:
Now you can pull down on the plastic piece and disconnected the two (2) plugs.
For this sensor twist it counter clockwise.
Press on the tab and release the wire for the light. Becareful not to touch the light it will be as hot as hell.
Step 5:
Next slide the white handle over.
Step 6:
On the sides of the filter lid you will see a metal tab. Take a small screw driver and pull outwards.
Step 7:
The filter will drop down.
Step 8:
Throw away the old filter and insert the new one.
Step 9:
Reinstall everything in the reverse order.
If you have any questions, just IM me
This is part of Service B just FYI.
Old Dec 27, 2012 | 08:09 PM
sinape62's Avatar
Veteran: Air Force
2013 C63 Coupe
Nice Lee, thanks!
