2010 w207 steering change
hi guys recently i bought a used w207 (2010) ,unfortunately mine does not come with the latest steering
this is my steering![](http://img.rnudah.com/images/93/9337773874.jpg)
i would like to replace my steering to this
![](http://img.rnudah.com/images/00/0016821132.jpg)
is it possible? if so how much would it cost (just the steering and labor)
thank you !
also will there be any complications to the airbag if i change my steering?
this is my steering
thank you !
Do you have the E-Class coupe or sedan? The coupe is C207 and the sedan is W212. Anyways, I am pretty sure that the swap is a direct plug & play. I have that steering wheel on my 2012 and it is magnificent.
Edit: you will need a new airbag as well.
damn ! new airbag ! According to Caker he got his Steering together with the airbag ..
https://mbworld.org/forums/e-class-c...heel-swap.html
There ya go buddy, hope that helps a bit. If you have any other questions I can try to help. You can probably find a newer steering wheel at your local auto wrecker, ebay, or in the forum classifieds.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
hi gavrocool care to share how much does the new steering cost? is there any risk or complication that might arise from changing the steering? and btw is the 2012 pre facelift steering is the same as the 2014 facelift steering?
My steering wheel is from A class.My electrician from MB made some changes so that it will fit,but i have no problems with it.
If steering wheel is produced before June 2012, then you do not need new contact plate for your 2010/11/12(prior June)
Hi,
Constructors MB considered it necessary to replace the steering column module for C and X-Class in 2012, E-Class and the other models of sufficient just to replace the steering wheel.
For the C-Class is also not obligatory (because the cost of steering column module $250) - will simply not work backlight buttons.
Now all sell only new steering wheels from 2012, because the wheel before 2012 does not produce!
I have access in Germany to restricted parts of, respectively I can equip steering wheels necessary parts.
Regards
- zh.k
The guy who replied to you with name zh.k, is the one from whom i bought the contact plate ( i found him on ebay, bought airbag, but after had problems and he told me to replace plate, i bought it from him for 160 euro with delivery ).
If your car is 2010/11/12(prior June) you should buy steering wheel which was produced in this dates. if your steering wheel is 2013 ( as mine was) you have to buy contact plate.
His email adress is piston77@yandex.com, this guy is very good seller, bought airbag and contact plate from him through paypal.
is everything working fine now?
I ordered new contact plate from this guy. Then , I have replaced it with existing one and everything started to work perfectly.I am very happy with it.
I bought performance steering wheel from cls63 amg.
After i installed new steering wheel, nothing worked (multifunction or paddles or horn signal). my car is 2010.
guys i was quoted by a local workshop for about 1150$usd for the new steering (I did not asked if it was inclusing of workmanship)
but is there anything i need to know when replacing my steering? thanks! what about the plate? do i need to aswell? with the plate affect anything?
