2012 E550 Cab ECU Tuning
As for what it does..... it can give a car a little boost in power or in the case of the 4.6 BT engine (which the '12 and '13 550 has), a big kick in power. They often remove the speed limiter function at the same time.
Most cars can be reprogramed through a port in the car (often the OBD diagnostic port), however to reprogram the 4.6BT engines, it is required to send your ECU unit to the tuner to reprogram. Most tuners I have read about claim a one or two day turn around at their shop for this. You will either have to remove the ECU yourself and send it in or find a shop to do it for you. If you are close to a tuner, you could also take your car to them.
There are a couple companies on this forum which offer tuning for our ECU's. Many forum members like Eurocharged although I believe Renntech is boasting higher power levels (but the price is also higher).
Although the 550 BT engine is "only" rated at 402 H.P., some reports show the real numbers are much higher when tested on a dyno or from track results.
I'm sure removing the cats will still result in decent gains, but the process improvement guy inside of me is saying "don't waste time increasing capacity AFTER a bottle-neck".
Also, it looks like MBH is seriously backlogged and are pushing out orders over a month (and apparently not answering the phones).
Weistec replaces that part and is clearly the superior product, but I'm not dropping 5K for some bent piping... Might just wait until someone else comes out with a similar product and prices drop.
Would also love to hear what it sounds like on a M278 with the downpipes (and stock resonators and mufflers). Put turbo back exhaust on my old WRX STi and the drone / rice effect got old. Not doing that to my Merc.
