Does E500 have the same ET , wheel spec etc. as E350 and E250 ? For example, configurator at official Borbet web page tells that 19' model called "XRT" is available only when you choose E500.
Front 20x8.5J ET 44
Rear 20x10J ET55
Michelin Pilot Super Sport 245/30/20 & 285/25/20
Bilstein PSS10 at lowest setting
Front has 12mm spacer to clear the AMG caplier
No rubbing so far
Your car is gorgeous, would you mind telling me what rear diffuser and spoiler you have?
I really need help, I am currently in Miami Florida, I would like to buy wheels for my E coupe in Morocco. I just don't understand what offset do I need. Im not planning to lower the car. I just want to use 245/275 on 19'inch wheels.
I would really appreciate if you can tell what brands can I search for ? what offset do I need ?
Hello everyone, I wanted to know what do you guys think about this setup. Stock suspension (maybe down the road some H&R springs if the car looks too high)
TSW Mirabeau
19x8.5 +32 235/35/19
19x9.5 +40 275/30/19
Curious which "stock" wheel you guys think would look good on a steel gray E350 coupe (haven't bought it yet), those sweet concave $1500 wheels are too pricey for me though.
I currently have the MB512 style on my W203 C230 because it has the deepest concave rear wheel of any stock rim I've seen. Unless another rim has a bit of a concave I might buy another set of those for the E350.
I have horrible potholes in the city, should I stick with 18's or risk 19's?
Also, for the time being while I go the cheap route and not buy new wheels right away, what's the largest spacer I can fit without rubbing on stock suspension with stock 6 spoke 18's and stock tires?
the wheels will fit no problem but wont be aggressive. Most advice for good fitment from this and many other threads is +35 to +40 on the front and +42 to +48 on the rear.
Also, tire sizes matter in fitment ... without information regarding tire sizes you plan to use fitment advice can't be perfect.
Was planning to use the normal 235/35/19 fronts and 265/30/19 rears..the wheels I mentioned are C63 507 Edition replicas which I really like but I can't seem to find them in any lower offset
THANK YOU FOR THE THREAD, and thanks to everybody for replying!!!! The summer is coming up and I am currently looking for new wheels and tires so this is extremely helpful!
Help please! Will this setup fit? Stock suspension, have no plans on dropping car
2010 e550 coupe
19 x 8.5 et 35 with 245 tires
19 x 9.5 et 40 with 275 tires
If this works, will I be able to use 285 on the rears?
Your feedback is greatly appreciated
The front setup will be perfect with 245/35 tires, the rear will poke outside the rear fender especially if you go with a 285 tire. You will likely rub the fender over bumps or with weight in the back. If you go with a 275/30 tire on the rear the offset should be around 45, and with a 285/30 tire the offset should be about 48 or 50 on the 9.5 inch rim.
