Dyno Mode for 2014 E550
2014 E550 CAb
I had an OE tune done on my E550, and want to see the Dyno results. Two shops do not know the "secret handshake" to put my 2014 E550 in Dyno mode. Appreciate it of anyone would provide the combination?
I FOUND THE SECRET HANDSHAKE: HOLD ANSWER CALL BUTTON AND "ok" BUTTON.
Last edited by Earlj4321; 06-26-2014 at 02:45 PM. Reason: Original input not clear
"You can disable the stability control with the steering wheel controls, but this does not disable traction control. To do that, you have to enter the engineering mode and put the ECU in dyno mode. Dyno mode didn't work so well last time at the track since it disables the torque-vectoring via ABS." from the post below.
https://mbworld.org/forums/e-class-c...ml#post5973957
