A207 aircap fuse
the aircap of my e class doesn't deploy when I press the button
no lights on the button neither.. can anyone tell me where is located the fuse for the aircap? it's written in the fuse chart (you can find it together with the spare wheel)
unfortunately I don't have the fuse chart because the previous owner must have lost it ...
thank you guys!
thank you guys!
I get the impression that Mercedes tech's do not understand these very well, how to set them up and install.
When my first one failed it stopped in the up position even with the engine off and the key out. Your lucky if yours is in the down position.
Another way to check is to see if the rear headrests move when you hit the switch as they are part of the same control circuit.
You can also check the switch on the centre console which operates the rear headrests independent of the Aircap switch.
yes when I press the switch between the seats the rear headrests move, but the wind deflector on the windscreen does not. Also the lights on the switch don't work. do you think is the same problem as yours ?
thank you
I have only ever seen one for sale on ebay, and that was damaged cosmetically due to the windscreen being replaced.
This is another issue, I understand that windscreen replacement companies do not like working on the cabriolet because of having to remove the windcap to replace the screen. Having removed it they have issues resetting and adjusting it to ensure a close fit.
If you take it to a Mercedes dealer they can tell you quite quickly what has failed via their diagnostic software. But be aware of the price it is no joke!!!!!!!
To be honest I considered not having it fixed as the car was out of warranty, but Mercedes did help out (gesture of goodwill) so it is worth asking especially if you have had the car serviced via main dealer.
this is a very late reply but at least we have the right audience and case here.
I may have the same issue in my 2011 E550; there's power, the button lights up, and the aircap struggles to open but it doesnt
Does anyone have a bit more detail regarding the ECU update? and how to reverse it/fix it.? is it possible to do at an independent shop or outside the dealership in general? it seems every time I go there the estimates are massive.
thanks
M
P.
