E63 AMG brake kit on E250 Coupé ?
i've used the search and i'm still in doubt here.
I've found me a bargain, the AMG E63 Brake kit for less then 700$ (for the four calipers).
But the problem is, i've read that it does fit but you need to use the E63 discs aswell otherwise it would not.
Can anyone tell me for sure that this is true. Anyone on here fitted this on a E250 Coupé ? (Diesel engine)
Thanks alot !
https://mbworld.org/forums/e-class-c...em-ecoupe.html
"HEEEEEEEEEEEEEEEEEY.It won,t fit.I tried to do that.Can,t you see that i choosed other brakes?BREMBO has no upgrade for E coupe.K sport it is not the best but it is what we need for street use.Remember that i am running 380mm front and 356mm rear,set up that it would have costed me double at BREMBO.Anyway i would have choosed BREMBO but as i said they don't have an upgrade kit."
But i'm not sure if i can take his post serious...
