Warping rotors
PJ
I bought a 2014 650i Gran Coupe, not a single issue and $0 for any services/maint for 4 years. Suck it MB.
Someone also filed a class action against mercedes relating to this.
In the end, I went with Stoptech rotors and EBC pads.
Cheaper than OEM... but i'm afraid the problem will come back. I changed pads this past Summer, but I can already tell some pulsation when braking hard. Not very smooth compared to other cars i have owned.
I truly believe its only one side of the rotors with the issue. In my case, the drivers side rotor wears unevenly compared to the front passenger side. Could be caliper is pulsating unevenly or the ABS is not calibrated correctly. Just throwing out possible ideas.
Basically, at this point my is at 41k miles i'm probably going to find a used set of Brembo calipers from C63, and switch my fronts.
I have ELW for another 3 years or another 60k miles. This coupe is not going anywhere for a while, I'll try to make the best of the situation.
