Connecting a sub/amp to standard COMMAND system
Old Feb 25, 2015 | 07:57 AM
R4vvm's Avatar
W207 Coupe
Has anyone fitted a sub/amp into an e-class coupe.
If so, how do you connect it up and also is there anywhere i can buy a boot install or a specific sub box to fit in the coupe?
Old Feb 25, 2015 | 09:40 AM
NCBob's Avatar
2012 C63; 2011 E350 Coupe
Try these. I plan on installing a powered sub and needed info on a switched power source in the trunk. I've already run the main power wire from the front battery to the trunk. Now I need to mount the sub and tap into the speaker wires located in the package shelf.
A powered sub comes with its own enclosure. Also it is much easier to install. No tapping into the head unit, which is a mother to access.
https://mbworld.org/forums/c-class-w...install-2.html
https://mbworld.org/forums/glk-class...subwoofer.html
http://www.benzworld.org/forums/w212...questions.html
http://www.benzworld.org/forums/c207...x-details.html
http://www.benzworld.org/forums/c207...use-trunk.html
Old Feb 25, 2015 | 11:55 AM
R4vvm's Avatar
W207 Coupe
Thanks, whats a powered sub?
Old Feb 26, 2015 | 10:33 AM
NCBob's Avatar
Bazooka, Boss, Infinity make powered subs.
A powered sub has its own built-in amp. All you need is a 12v power source, a switched power source and a way to connect it to your existing sub in the package shelf.
The Command has a sub in the shelf. Not sure if there is a sub with the standard audio system.
Bazooka sells a quick-connect harness that taps into your existing sub connections.
