NEW Facelifting and retrofit project E550 CAB
Rating: Thread Rating: 4 votes, 5.00 average.
Old 01-10-2019, 04:05 AM
  #401
Chris The Swede's Avatar
W222 S63L, ML/GLE350
Originally Posted by Piotr Faron
I bought this new frame but it does not fit well. There is a big gap between it and the screen. How to manage that?
You have to mod it...
Old 01-10-2019, 04:06 AM
  #402
hi. I installed the facelift switch panel and the belt extender does not work. How can Ii be done? Does it need coding?
Will never work again affraid. There is no solution.
Piotr Faron (01-10-2019)
Old 01-10-2019, 07:16 AM
  #403
Piotr Faron's Avatar
w207
Ok, Done that, Thought it was a direct mount. Thanks for info
Old 01-10-2019, 07:18 AM
  #404
w207
That is a sad info- I just thought maybe the new panel is faulty or it needs to be coded,
Old 01-10-2019, 07:30 AM
  #405
w207
Got these..$150 Each..
Hi, Can I use the prelift PDC sensors or do I need to get the bumpers with the new ones. ? What is the procedure?- same mounting- samo socket?
Old 01-11-2019, 03:27 AM
  #406
You can use the old. I just used stripes to hold them in place in new sockets. Works perfectly.
Piotr Faron (01-11-2019)
Old 01-11-2019, 03:45 AM
  #407
w207
And If I get the new ones - are the sockets just plug&play?
Old 01-11-2019, 04:32 AM
  #408
They dont work with old cable harness.
Old 02-12-2019, 09:40 PM
  #409
northridgeaz's Avatar
2011 E550 Cab
Hey Chris, Your Facelift project is a must read for all of us with a 2011 model. While I enjoying reading all of it I’m working on my 2011 E550 cab a little at a time. The part I’m asking about is the transmission position indicator that you have as #A1722670388. My question is will this work in my car without changing the dash switch plate A2079053102. And if so how hard is it to replace and where can i get one. For reference i am located in the U.S.
Thanks for sharing all of your knowledge!
Old 02-14-2020, 06:31 AM
  #410
BanicaA's Avatar
Mercedes e350
W212
Hi how can i get in touch with you chria the suedes?? My email adress , ionut_banica92@yahoo.ro
thanks
Old 02-16-2020, 01:35 PM
  #411
BanicaA's Avatar
Mercedes e350
Originally Posted by xMaximus
What is the part number on that switchboard? I have parking sensors, ESP, heated seats, head rest, and rear sunshade.
hi...did you find the number part for the panel??
solar panel heating seats etc??
can you tell wich it is if you found??
thanks
Old 05-16-2020, 08:17 AM
  #412
lbegiss's Avatar
E550 coupe , S550 w221, X5m50d, Cayenne GTS
Hi Chris
how are you ? Do you still have the Mercedes ? Congrats on the job you did ! I have a E500 coupe 2010 and I’d like to do some mods.
would you consider putting the new aftermarket Screen that’s sold on Aliexpress ? I am tempted to buy one so I can use Apple car play.
How can I send you a PM message ?
Thank you
Old 05-18-2020, 09:17 AM
  #413
Sold long ago.. Send like usual.
Old 05-19-2020, 10:59 AM
  #414
Josh Arias's Avatar
MERCEDES BENZ W212 2015
do you have an instagram?
Old 05-19-2020, 12:53 PM
  #415
yes. Cant write it here though. Censored.
Old 05-20-2020, 04:14 AM
  #416
w207
Hi- Yes- would love to have it enabled.
How can it be done?
Old 05-20-2020, 04:16 AM
  #417
w207
but the clock works.
Only the seat belt button does not work
Old 05-20-2020, 04:45 AM
  #418
Will never work on facelift switchrow.
Old 05-20-2020, 04:47 AM
  #419
w207
so bassamsino is wrong?
Use Vediamo and make the following modifications:
CRCM_207 (Deactivate EFS Switch) >>> Reset
Front SAM (Disable EFS) and (Enable Clock) >>> DL_EEPROM_Schreiben >>> Reset
This will enable presenter in facelift Switch panel and Clock will be visible and accessible.
Old 05-20-2020, 09:45 AM
  #420
He might be right with that. But that is ONLY if you have Star Diagnose and Vediamo...Otherwise never.
Old 05-20-2020, 09:56 AM
  #421
Originally Posted by bassamsinno
Chris, I know what am talking, and it was very clear when i told you use vediamo, and also you can do it on star, it so easy step.
Very good. Good share.
Old 07-12-2020, 05:57 AM
  #422
Quince99's Avatar
Mercedes E250 CGI Coupe
The process you have shown has been inspiring Chris and I've started work on my E250 coupe with the interior silver parts, vents and so on. I've put the clock in and changed the blue connector to the black one with the wiring in the same order as the blue one:
1 - Red
2 - Brown
3 - Grey/yellow
These read from right to left on both connectors plugs. Of course having done so, the clock does not pick up the time from the car's systems.
According to this upgrade video:
The guy plugs it in and the little hands whiz round to the right time - brilliant! Looking at this though, it appears he has three wires to start with but when he plugs the black connector into the clock, it looks as if there are only two being used.
Any help and clarification would be most appreciated and, looking at previous comments, does this actually require software?
Old 07-21-2020, 04:38 AM
  #423
Yuvraj Dubey's Avatar
A207 2014 E220 CDI
Hey Chris, sent you an email about upgrading static to LED lights, couldn't find much information on the facelift A207 only on the non facelift and the W212 E class. Hoping you can help me
Old 07-21-2020, 04:41 AM
  #424
And mails are answered.
Old 07-21-2020, 10:49 AM
  #425
A207 2014 E220 CDI
Hi, I haven't received the mail, it might be because I have logged in with Google instead of making a fresh account. Am I allowed to PM this to you or edit this message with my email?
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: NEW Facelifting and retrofit project E550 CAB
