E350 w212 Brake replacement
Old Jan 11, 2016 | 05:42 PM
Snoopymac's Avatar
Mercedes E350 w212
Talking E350 w212 Brake replacement
Hi Everybody,
I am new, so please understand if I make a mistake....
Could anybody advise me as to a possible issue with replacing the front brake discs and pads on my 2011 E350 Coupe Sports. As I have been told that there could be an issue with compressing the calipers? I have been told it could course ABS issues.
Thank you in advance
Snoopy
Old Jan 12, 2016 | 01:12 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to C207 forum...
you can manually compress the calipers...
Old Feb 3, 2016 | 04:31 PM
Late's Avatar
03 SL500(Sold), 09 C300, 11 E550
Originally Posted by Snoopymac
Hi Everybody,
Snoopy
I've changed pads and rotors front and rear. It is a standard procedure, no special equipment required. If you are having trouble with compressing the caliper back in try buying a caliper compressor tool. It is basically a big Screw with a metal plate that you can place against the piston and unscrew until the piston is compressed again.
A C Clamp and scrap piece of wood on the back side of the caliper is my preferred method
Old Feb 3, 2016 | 06:29 PM
nauticalx's Avatar
Do you guys know the torque specs for the caliper bolts?
