HELP: Replacing position/parking lights between the headlights
Old Mar 21, 2016 | 07:45 PM
Kevin9664's Avatar
2011 E550 Cab & 2015 ML400
So I've noticed that the position/parking lights between the headlights and grill do not match the Xenon lights well so I wanted to change them. For starters, they are not the W5W bulbs like the manuals says they are. They look like a little green chip. I'm having difficulty taking them out though. I was able to stick my phone down and take a photo.
Has anyone done this that can provide insight? Can it be done without removing the headlight unit? Also, does the front bumper need to be removed to remove the headlight?
http://www.ebay.com/itm/181985075012
Attached Thumbnails HELP: Replacing position/parking lights between the headlights-img_0669.jpg   HELP: Replacing position/parking lights between the headlights-s-l1600.jpg
Old Mar 23, 2016 | 01:02 PM
nauticalx's Avatar
i was wondering the same. seems like it should slide out and fit perfectly. id ask the seller to confirm, that way you can return it if it in fact doesnt.
