C63 brakes on E550 coupe
Old Sep 29, 2016 | 08:42 PM
bill_097's Avatar
C207 - 2011 E550 Coupe
Hi,
I've been searching the forums, and it seems that there is little/no modification required to get the C63 sedan (W204) brakes onto the E550 coupe, but I just wanted to confirm with people that have actually done the change if that is true. I recall mention of some bracket?
Any help would be much appreciated.
Old Sep 30, 2016 | 04:00 PM
Dueclaws's Avatar
'12 E550C, Sierra Denali
I don't believe the C63 brakes are "bolt-on" to the E550 coupe. Keep researching: custom caliper mount bracket is required from what I understand.
I never tried to install the C63 brakes since my 2012 E550 coupe has the larger front rotors (same size as some C 63's) and larger front brake calipers and pads.
The stock front rotors warped; thus, upgraded to high quality (not OEM) drilled rotors front, grooved rear rotors plus high quality low-dust pads front and rear.
Old Sep 30, 2016 | 04:49 PM
2010_E550's Avatar
2010 E550 Coupe
Yes, its possible with a bracket for the front caliper. Contact Ivan, he makes and sells the bracket. http://www.dctms.com/Products.html
I have completed the conversion. Purchased the OEM calipers & rotors online, at discount, through www.parts.com
C63 SS brake lines bolt right up. I am also running C63 Porterfield R4-S pads. They squeak a little bit, but once warmed up they bite hard.
Old Oct 1, 2016 | 01:04 PM
bill_097's Avatar
Thanks for the replies
I'm guessing they no longer have the calipers available? All I can find are Pads, rotors, and backing plate for the C63:
https://www.parts.com/index.cfm?fuse...3-%20Liter-GAS
Do you recall the part numbers?
Thanks again
Old Oct 1, 2016 | 09:09 PM
2010_E550's Avatar
2010 E550 Coupe
Its there...
The caliper is located under hydraulic system.
https://www.parts.com/index.cfm?fuseaction=store.sectionSearch&storeid=2 &vehicleid=314493&section=BRAKES&group=HYDRAULIC%2 0SYSTEM&subgroup=FRONT%20BRAKES&partscomponent=CAL IPER&Title=Mercedes-Benz
Old Oct 5, 2016 | 10:43 PM
LGAFF's Avatar
2011 E550 Coupe, 1992 Corvette ZR-1, 1991 368ci ZR-1, 1990 ZR-1, 1987 Callaway TT, 05 SL600, CLA45
front are big already, I put the rear C63s no mods, huge difference in braking
