Radio Amplifier Question
2011 e350 Coupe
Hello,
I have a 2011 e350 coupe, and I believe my amplifier blew out (no sound comes out of the speakers on any mode anymore).
I found a replacement refurb for $205, but I wanted to run it by the community and see if it is a simple plug n play when swapping them out, or if it will require programming?
Any help would be greatly appreciated, this has been a persistent problem that I would like to solve immediately.
Thanks!
Thanks!
2011 e350 Coupe
The command wheel had a stripped wire which was shorting everything out, so in removing and replacing it, it caused a spark which led to my sound no longer functioning. That's what leads me to believe i shorted the amp out.
The display did not work for a while, until i reset that fuse (#11 i believe), then it came back without the sound.
I would suggest to check it out at a car accessory shop that specialize in car sound. It should cost less than $50 for them to check the amp output to see any signal coming out of the output. This way you will know for sure before you swap out the amp. I am a home sound buff but the principle is the same.
2011 e350 Coupe
