2011-2012 e250 cgi (c207)
Old Jul 1, 2017 | 10:09 PM
amglawyer1's Avatar
c180 1.8 2012
Hello everyone!
First of all sorry if i'm posting in the wrong section and sorry if a question has been asked like mine (i did a small search but couldn't find any).
Let's get to my question: I'm looking forward to buy a e250 CGI C207 2011-2012. It's what i can afford at the moment and it is what i will buy Not looking forward to buying other models /newer models. Anyway, i did some research and for the 2011-2012 e250 CGİ coupé, it says that its 7G tronic on some websites, and some show it as 5 shift gear box (automatic). Anyone have any idea which one is correct? Are 2011-2012 e250 CGİ cars 7g tronic?
Another question is, what should i be aware of when buying a used e250 cgi? What are the common problems? Any specific things that i should check?
Sorry for the bad English, it's not my native language. I hope you can answer my questions, especially the 7g tronic one!
Thanks in advance!
Old Jul 2, 2017 | 03:34 PM
amglawyer1's Avatar
c180 1.8 2012
Anyone that can help? )
Old Jul 3, 2017 | 02:02 PM
BenzMan369's Avatar
2012 E350 Coupe
Sorry you aren't getting much help here. One reason may be that the E250 is rarely if ever mentioned on mbworld to my knowledge. Have you tried European or other forums?
In the U.S.A., there were notable differences between model years 2011 and 2012 E350 and E550 C207's. Both had seven speed transmissions, but the trans was tweaked in 2012 to be more responsive and to mate optimally with the new V6 Direct Injection engine that replaced the V6 in prior year C207's. The trans was re-named 7G Tronic Plus to reflect this. But none of this helps you.
Again, try some other Mercedes websites and perhaps do a more in-depth web search. My quick search before posting this came up with the 5 speed trans showing on both the 2011 and 2012 E250. A 4 cylinder engine was also mentioned on one site.
Good luck.
Old Jul 4, 2017 | 01:19 AM
xsever's Avatar
2012 C300 4MATIC Sport
Originally Posted by amglawyer1
Hello everyone!
Thanks in advance!
We can definitely give you an answer if you post the car's VIN.
In addition, based on my research on www.automobile-catalog.com , the 2011 E250 BlueEfficiency Coupe has a 7-speed gearbox whereas the 2011 E250 CGI Blue Efficiency Coupe has a 5-speed gearbox.
For 2012, it's the 7-speed across all models.
Hope this is useful.
Old Feb 11, 2018 | 07:58 PM
mengshi's Avatar
E Class
C207 2011
Have done some reading myself. The small capacities C207 are often seen only in the South East Asian region plus some in Australia. If the C207 has Eco mode then the gearbox is a 7G-plus (which was introduced in 2011 I think).
BTW, the VIN checker available online is it for USA cars only or International? I can't find a VIN checker for Singapore.
Old Feb 12, 2018 | 01:37 AM
xsever's Avatar
I use this one and it works internationally. Give it a try.
www.vindecoderz.com
