Window Issue
Old Jan 3, 2018 | 08:24 PM
Davery's Avatar
2012 E550 Cabriolet 2011 VW Eos 1985 Pininfarina Spider
Window Issue
I am having an issue with the rear window. When the door is opened, the window drops slightly to allow the door the clear the rubber molding. When the door is shut the window goes back to it's original position. The rear window also drops slightly, but is not returning to it's original position. Any ideas what is going on?
Old Jan 3, 2018 | 09:42 PM
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
this happened to me as well. you’ll need to reinitialize the particular window. the process is easy, start the car as normal and pull up on the window switch and hold the switch for about 10 second - this may need repeated a couple times... this will reset the return window position. test for normal operation. cheers
Old Jan 5, 2018 | 09:27 AM
2150john's Avatar
E 450 4matic cab MY22
There is a reset procedure in the owners manual. I have had to do it a couple of times on my wife's car but it works.
Old Jan 5, 2018 | 04:59 PM
Davery's Avatar
I did the reset yesterday and it seems to have worked. Thanks!
Old Jan 6, 2018 | 04:34 PM
Thumbs up
~ excellent ... glad it worked for you.
