E350 rear window leaves gap
Hi guys,
I have looked around but cannot find a satisfactory resolution to this, I hope someone can help without me having to take the car in? My E350 C207 2009 has started to leave a 1 cm gap when closing the drivers door. ie. it is not making a watertight seal. This can be resolved from inside by pulling the electic window button up. On the first pull it will not close but on the second pull it clsoes. When I try to leave the car (by being outside it!) the gap will not close, so my only option then is to exit via the passenger door (!) or leave the car insecure and open to the elements. I have tried removing the relevant fuse for 20 minutes and putting it back (I have not replaced with a new fuse yet). The other thing that has stopped working is the function where all windows can be wound down from the outside (useful on a hot day) using the unlock button on the key fob. Is there some sort of reset process I can do on the windows?
Cheers
Cheers
Received 4,435 Likes
'71 Pinto
![](https://cimg0.ibsrv.net/gimg/www.mbworld.org-vbulletin/272x182/capture2_7a084261189180783b30729a5238262e15506b86.jpg)
![](https://cimg1.ibsrv.net/gimg/www.mbworld.org-vbulletin/285x326/capture_631b43fbbfe2c152440806969e7ff344a36f4d8b.jpg)
Have you tried synchronizing?
The following 4 users liked this post by konigstiger:
SMG_CT (01-18-2020)
Thank you for this information. I have a 2014 e550 and the left rear window was not completely closing, same issue. I followed the window synchronizing instructions and it worked like a charm, much appreciated.
SMG_CT (01-18-2020)
