Oil extraction, need help!
Anyone, who has done the extraction, can shed a light? Thanks.
Have you used the same extractor for those 15 years? If so, it may be time for a new one. If the tubes are reaching the oil, the tubes are clear and the pump is working, oil should be coming out. Of course, maybe the quantity of oil was much less than you think and you got all that there was. What does the dipstick indicate? Good luck.
Fashion a fitting that will clamp over the upper end of your dipstick tube and all your problems will be solved. That is the way the dealers do it and the way I have always done it on my 1983 300CD and my 2008 E320 Bluetec. I too use the MityVac extractor. BTW, loosen your oil filter cap first so it can drain into the sump and you will get that oil also.
I found an aluminum nipple with an o-ring that works. Don't know what it really is. Fits nicely into the dipstick tube. I think you can easily make something up out of rubber/plastic tubing and worm clamps. It would be equally as effective clamping and sealing to the outside of the dipstick tube.
