2014 E350 Coupe Speaker Model Number Help
Old Jul 10, 2018 | 10:00 PM
DGinMiami's Avatar
2014 E350 Coupe
Question 2014 E350 Coupe Speaker Model Number Help
Hi folks,
I'd really appreciate the model number for the Driver's side rear deck panel speaker. It's not the sub, i believe it's a midrange and it's supposedly a shallow harmon kardon (logic) speaker that can't be replaced w/ a different brand.
just bought this car w/ the blown speaker and i can't listen to sports radio lol
Thanks in advance!
Old Jul 10, 2018 | 10:05 PM
ItalianJoe1's Avatar
2003 CL 600
You want the OEM part #?
I would suggest, pulling the speaker out and replacing the driver, if you aren't gonna buy the whole unit from a dealer. The rear panel unit has a large and small speaker, what usually happens is the center cone pops off the small speaker (shop opinion is the big speaker vibrates it loose, but unsure if that's true), and then it rattles all around. The unit can be removed and the speakers could be replaced with a similar sized aftermarket unit, but from factory they only sell the entire dual speaker unit as one piece, and the new ones are no more reliable than what you have in there now, it will fail in a couple years if you play it loud at all.
Old Jul 11, 2018 | 10:04 AM
DGinMiami's Avatar
2014 E350 Coupe
Thanks again, Joe.
Where can go to look for the driver replacement (and specs finder)?
i was quoted $216 from MB and to replace just one speaker it seems a bit much assuming i still need to pay for the install (elsewhere of course).
Old Jul 11, 2018 | 11:27 AM
konigstiger's Avatar
'71 Pinto
OEM part # 2048205802, $110.91 https://www.parts.com/
Old Jul 16, 2018 | 01:20 PM
daynad00's Avatar
2014 E350 Coupe
I also bought a 2014 E350 Coupe with a blown rear deck speaker. I am having trouble finding the model of the speaker I need to buy. It is the upgraded Harmon Kardon passenger side rear deck speaker. Any help is appreciated.
Old Jul 16, 2018 | 02:11 PM
'71 Pinto
OEM part # 2048205702
Old Jul 17, 2018 | 12:19 PM
'71 Pinto
See attachments for replacement.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
