Next question. Sorry. Lower trim
Never been a fan of a red car with the exception of Ferrari’s. This red E Coupe is actually very cool [we can do without the windshield decal]. The silver painted V wheels really pop against the red paint work. You can really see the sleek lines of this E Coupe with the red paint and the drop.
The black one below has wheels styled as you would typically see on a Porsche 911. They gives this E Coupe a pretty good looking aggressive look.
When buying I saw this. it was overpriced but great colour. never seen it again on a e-class cab.
https://www.youtube.com/watch?v=aVFvOQo9h5Y
Some weekend diversion...
I grew up surfing in Southern California. One of the better point breaks is Rincon, which is about an hour’s drive above Malibu. This is a good size day at Rincon and just perfect. The advent of drone photography has totally changed the actual view of surfing from a photography aspect. You’re now out there with the surfers and can see the 3 dimensionally view of wave riding. With the drone, you can see the total landscape and all of the movement going on. It’s pretty amazing from this aspect.
https://www.youtube.com/watch?v=klAkzvJPyHY
Needs a small lowering too. can't work out what I can and can't do with the dynamic sports pack on the car.
Assume the trim on the door and below rear windows comes off OK as well? Or did you do some in place?
Buy the right tools and it can all be tucked and trimmed in place.
the doors you can lift up a bit easy enough with a plastic lever to tuck under easier
the A pillar use a true straight edge but if vinyl and run it .5mm over the rubber and it just tucks under the underside the rubber moves easily.
The roof clips in the rear were ther were their hardest and again removal would have been the same as the rear trim. But a bit of patience. It’s done in place fine.
Use quality vinyl it’s easy to work with.
Here’s a photo of your wheels when new. I actually like these wheels. There also a six spoke pattern, which is highly unusual for Mercedes.
Post some options as to what your thinking as to something else.
But instead just satin black to give this look.
The roof is fine. no issues with leaks. not really noisy at all. no more than any other car. the roof has a lot in it so its quite sound deadening. down the AIRCAP make a big difference and means its usable even in low heat. I reckon even in 10-12 degrees it could be used if you so desired.
