11 Cabrio Console Question
Old 09-23-2018, 07:38 AM
aqua190's Avatar
11 E550 Conv
I have an 11 E550 and the Command scrolling issue. I ordered the replacement shaft, but can't figure out how to remove the switches for the top controls. I have found several videos on removing the Command knob from sedans, but none that specifically address the cabrio. Can anyone tell me how to remove the trim around the Command knob? It looks like there should be less to remove than on the sedan, but I'm stumped and dont' want to break any trim pieces. Thanks in advance for any tips or advice.
Old 09-23-2018, 09:25 AM
400ixl's Avatar
E250 AMG Sport Convertible
For the European cars you remove the gear leaver cover and then the knob itself, followed by the trim that is then left. That gives you access to the screw at the front of the arm rest. You then remove the rear vent cover which gives you access to another 2 screws. They you remove the cup holder mechanism under the sliding door, remove the mat and there is a screw there. Once those screws are removed you can use trim removal tools to separate the top of the armrest
North American cars may be different.
beyonddevoted (03-04-2020)
Old 07-26-2019, 04:20 PM
Kevin9664's Avatar
2011 E550 Cab & 2015 ML400
Was 400ixl's response helpful? Have anything to add? I think I might be doing this tomorrow or Sunday.
Old 02-07-2020, 02:56 PM
bigemike's Avatar
e350 2011 cabriolet
I could use some more details on this as well, anyone made a video?
Old 02-07-2020, 11:15 PM
erich_aux's Avatar
2012 E350 Cab
bigemike,
Please refer to this thread: https://mbworld.org/forums/e-class-c...ml#post7736722
Between the pelicanparts article I shared and the pdf that Konigstiger shared, both should be helpful.
I used these to replace the convertible top switch housing.
I should have replaced my broken command wheel shaft at the same time!
Taking the console apart - for me - was a huge pain.
To me, replacing the shaft seems like a lot of work. I may just opt to replace the whole command wheel/unit.
Hope the above helps!
Quick Reply: 11 Cabrio Console Question
