Command uestion for those with 12-13(?)
Old Dec 24, 2018 | 05:21 PM
erich_aux's Avatar
2012 E350 Cab
When you turn your command knob, does it do anything?
No where in any function does turning my command knob do anything.
Old Dec 26, 2018 | 09:49 AM
Mr. Toad's Avatar
2016 E400 Coupe (C207)
Are you referring to the small knob in the center of the vertical dashboard area (just below the clock and HVAC vents), or the larger knob on the console itself (just in front of the clam shell storage bin/armrest)? The smaller one can be pressed to turn the COMAND screen on/off and can be turned to adjust the audio volume. The larger one on the console can be pressed, pushed up/down/left/right, and turned to make selections on the COMAND screen. If either of yours doesn't do these things, I'm sorry to report that you have a problem.
Old Dec 26, 2018 | 10:11 AM
erich_aux's Avatar
2012 E350 Cab
Thank you for responding. I am talking about the large knob in the center console. I have now found another thread about the knob’s shaft being broken. This could be the problem. Moving the knob forward/backward/left/right works fine. Just not the turning.
