Tire Pressure Sensor Missing
I recently purchased a 2013 e-350 coupe and I’ve been getting this message every now and then. This seems to have really started after I got my wheels plasti-dipped (tires were taken off and mounted back on). It’ll come on and then after driving for a while it’ll go away again. Anyone had this problem and how do I fix it?
All TPMS units connect via RFID and sometimes they do loose connections. There are tiny batteries in each TPMS unit that have a normal life between 7 and 8 years. Remember, batteries loose overall power in cold weather. However, most tire shops just replace the TPMS units to resolve the battery problem.
This happened to me with brand new TPMS units. On my car it happened once (so far) but later came back on its own after driving for about two hours. Annoying and frustrating.
I replaced my TPMS units with genuine MB TPMS units from this ebay vendor when I installed new wheels and tires.
Setting up the new TPMS units on a Mercedes is a bit complicated. Read this MBWorld thread , especially post #8.
BTW: You should only use a plastic air valve cap on a TPMS unit. Metal air valve caps may fuse to the TPMS valve.
I hope this helps you out.
I think that you should "let it ride for the winter"
You may want to consider purchasing the new TPMS units from the ebay seller that I mentioned earlier. The parts have the MB logo and part # and worked fine on my E350 coupe. The cost for a set of 5 is lest than the cost of 1 at a MB parts counter. Something to consider.
thanks
