URGENT HELP NEEDED fan on permanently
Old 02-23-2019, 03:21 PM
Mick996t's Avatar
E350cdi
Evening peeps I have an E class coupe E350cdi 2010 I went out today started my car from cold and the engine fan come on full blast and just stays on all the time has anyone had this before if so could you tell me what the problem was
Old 02-23-2019, 07:22 PM
Plutoe's Avatar
Received 1,021 Likes on 949 Posts
1999 E300TD
Faulty fan control unit!
Old 02-23-2019, 07:37 PM
Harold1898's Avatar
2015 E400 Coupe
Pop into a dealer ask them to diagnose and quote to repair. Even if you do not use them, you will know what to fix.
Old 02-23-2019, 10:13 PM
exhaustgases's Avatar
LS400
Most all electric fans use a temperature sensor to control them as well as a relay, so check both.
Old 03-03-2019, 09:00 AM
Uky
Uky's Avatar
C238
If the Fan control box looses the CAN connection to the engine controller (which knows the engine temperature) the Fan will run at
maximum speed in order to protect the engine.
Therefore, Check all connectors for moisture and/or galvanic corrosion. Wiggle and dis- and reconnect the cable
that goes to the Fan controller.
Quick Reply: URGENT HELP NEEDED fan on permanently
