Coolant problem leaking engine noicey HELP
Hi, I have a Mercedes e250 convertible
My coolant went low I topped up, Temperature gauge did not go into hot, Coolant then come up again Smoke from engine, no coolant completely empty Top of engine melted, from the engine cover and tape. Two videos I attached , one when I key on with engine started What you think wrong, also is it safe to drive or would you not advise Thanks
Do you have skills, tools and a location (garage) to fix your vehicle? The people on this site can help you.
If you do not have tools, skill and space to do the repair work, then you should take your vehicle to a Mercedes dealer or qualified repair technician. The Mercedes dealer or the qualified repair technician can fix your vehicle.
Possible causes for coolant coming out of the engine are failed gaskets, failed hoses, or broken components like thermostat housings or water pumps.
