Odd behavior. Alternator?
I have a 2011 E550 Cab. car has 80k on it and is well taken care of. Last week engine light came on. My indy pulled the codes and it showed both upwind O2 sensors bad. He mentioned it might be an alternator issue instead and reset the codes however didn't have time to test the alternator. I drove the car for the entire next day and she was all good. Started car this am and after putting in reverse she almost died and the engine light came back on ( not sure if it's the same codes or not) . Then the car started revving on its own. between 1k and 2.5k back and forth slowly. Couldn't get it to idle correctly and obviously can't drive it with it changing engine speed on its own. Also sounds like its missing. After this the warning comes on that the ESC system is not available / disabled.
The car has a AGM Interstate battery that I installed 4 years ago. Smartcharger said battery was borderline good (80%) and its taking a charge now.
I'm obviously nervous about taking it to dealership however not sure if my local indy has the expertise to diagnose / handle. I think this all this leads up to a bad alternator however I just don't know. I think that the car was acting wonky right before I replaced the battery last time just can't remember the symptoms.
Any suggestions would be appreciated.
