Caliper Options
Old Dec 31, 2019 | 01:44 PM
LGAFF's Avatar
2011 E550 Coupe, 1992 Corvette ZR-1, 1991 368ci ZR-1, 1990 ZR-1, 1987 Callaway TT, 05 SL600, CLA45
Caliper Options
What are my front caliper upgrade options for the 2011 E550, I have rear C63s.... I did see recently someone swapped on news front calipers from a more recent W212 E550 sedan, does the same work for the E550 would like to move to a 4 piston up front....
Old Jan 4, 2020 | 05:26 PM
fookoff mate's Avatar
Hanz
Buy e63
Old Jan 4, 2020 | 05:28 PM
LGAFF's Avatar
This is just a daily I commute with, already have a slew of cars..... CLA45, SL600, SLK55, 3 90s ZR-1s and a 1987 Corvette Callaway
Front Brakes just suck on this one....
Old Jan 5, 2020 | 04:36 PM
PhuongNguyen's Avatar
2013 E550 coupe
What did you pay for the rear AMGs? Yes you could swap the new 550s front for cheaper. It’s actually the same size and piece rotor of the c63 non performance package. But the c63 has better calipers/pads.
i was thinking about getting some c63 calipers for the rears too since it’s bolt on no bracket needed. But for 700, I’d rather just update the stock system to centric/posiquiets
Old Jan 5, 2020 | 05:35 PM
LGAFF's Avatar
I waited patiently and got them for about 400
Old Jan 5, 2020 | 06:14 PM
2013 E550 coupe
that’s super cheap. Can you feel a huge difference in braking?
Old Jan 8, 2020 | 06:59 PM
LGAFF's Avatar
Picked up set of fronts for $700 ….
Old Jan 8, 2020 | 07:15 PM
2013 E550 coupe
you have to get a special bracket for them. Cost like $450. Did the set come with a good pair of rotors?
Old Jan 8, 2020 | 07:22 PM
LGAFF's Avatar
Going to get new rotors
Old Jan 14, 2020 | 07:44 PM
LGAFF's Avatar
Calipers arrived and brackets are on
Old Jan 14, 2020 | 07:54 PM
2013 E550 coupe
What custom brackets did you use?
Old Jan 14, 2020 | 08:55 PM
LGAFF's Avatar
Got a set off ebay for $400
Old Jan 28, 2020 | 04:49 PM
griza's Avatar
2006 CLS55 AMG Sold 2010 E550 Coupe totaled by mechanic, '13 SL550 I totaled it, 2017 SL63 current
Are these off a C63 or E63? Was considering doing a similar swap
Old Jan 29, 2020 | 11:01 PM
LGAFF's Avatar
C63 I will post up my progress when I do the swap
Old Mar 14, 2020 | 04:58 PM
LGAFF's Avatar
And its done.... found a set of brackets on ebay….. pedal feels better and great stopping power once you get into the brakes...
Old Mar 16, 2020 | 10:12 PM
griza's Avatar
Looks like a super tight fit under those rims. All in all worth the expense and effort?
Old Mar 16, 2020 | 10:17 PM
2013 E550 coupe
can you show me where on eBay for the brackets? Also what pads and rotors did you roll with?
Old Mar 17, 2020 | 07:55 AM
LGAFF's Avatar
The bracket was someone selling off a pair that they apparently didnt use, I used Centric C63 rotors with coating to prohibit rusting as I live in midwest, Pads were StopTech pads. As far as whether its worth it, Ive owed this 2011 since 2012 and its been a great car. I plan on keeping it for awhile, the old rotors were shot, and calipers were poor on braking...its tuned and I now have front and back C63 setup. Alittle upgrade motivates me to keep it and honestly I would get another one so would just take these off and tranfer to the next......I had the rear calipers already.. paid $800 shipped for fronts..did all the work myself and upgraded to stainless caliper lines.....
Old Mar 17, 2020 | 09:01 AM
2013 E550 coupe
I have the 2013 550 so the brakes were already upgraded from factory by then. In fact the 2013 550 and c63 non PP uses the exact same rotors. I changed pads to posi quiet and added ss lines on the front myself. Brakes much better now. If I could find rear c63 calipers for 400 or less I would do it since the c63 is 20mm or 30mm bigger. But as far as the fronts I do t wanna pay 1400 for caliper and bracket so I’ll just keep it the way it is. Upgrading the pads and adding ss lines made a big improvement already.
What brand ss lines did you choose? Goodridge?
