2010 E350 A207 Convertible Roof
Old Mar 3, 2020 | 04:29 PM
Kev1983's Avatar
2010 E350 A207
Hi
have an issue with the soft top.
opened it today no issues - rear and front wind deflectors up and all 4 windows.
got home pushed the close switch and nothing at all no pump or windows opening etc .
When try and re open you hear pump run for few seconds max. Still nothing closing.
tried raising and lower wind deflectors and windows but still won’t close.
closed and locked it manually (not an easy task!)
opened it again with no issues but same again won’t close.
Closed and locked manually again - tried the close switch and can hear pump run for a second or two.
haven’t tried opening since as started to rain.
any thoughts on where microswitches are located or which ones could stop it from closing only!
I have checked the boot shelf switch originally (but obviously working as opens)
thanks
Old Mar 4, 2020 | 08:37 AM
konigstiger's Avatar
'71 Pinto
Have someone pull fault codes using MB diagnostics, see attachments to better understand system.
Old Mar 4, 2020 | 09:50 AM
Kev1983's Avatar
2010 E350 A207
Thank you had been looking for something like that. Hard to find all the micro switches in situ.
Old May 1, 2025 | 01:43 PM
eddierolls's Avatar
w212
Did you find the problem?
Ours is now doing exactly the same thing.
I'd rather not rip the whole system apart if I can avoid it!
Old May 1, 2026 | 07:22 PM
hsn123's Avatar
Did you manage to get to the bottom of this, my ripoff is paying up in exactly three same way...
Old May 5, 2026 | 08:40 PM
eddierolls's Avatar
w212
Ours was caused by the micro switch on top of the windscreen on the (UK) driver's side being stuck.
We pushed it in and out a few times and it started to click again and the roof worked.
